Button with extra padding by enabling dynamic content
    I’m working on a “popup” to display author information.
    Inside that container I added a couple of buttons with icons only.
    Everything looks normal until I enable dynamic content.
    Once I do that, both buttons show an extra padding to the right.
    If I disable the dynamic content, the padding goes away.
    Not sure why that happens.
    Thanks for your help!
    Denise
  • Hi Denise,
    Did you toggle the remove text option in the icon panel?
    If not, please do so, let me know if this helps!
  • Hi Ying,
    I did.
    What I noticed id that when I activated the dynamic data is when that padding is added.
    If I disable it, it goes back to normal (same padding all four sides).
  • Can you try setting the column-gapto 0 for the button blocks? The setting is in the layout panel.
  • That was it!
    Issue resolved.
    Thanks Ying!
  • Glad to hear that 🙂
