Dominik
if we need global icons in buttons (like an arrow) we don’t use the generateblocks icon method, because icons that are added to global style buttons are not affecting the buttons used on the website. Instead we add it with css pseudo-element :after. This has the disadvantage that it is not affected by currentColor of the buttons text or icon color.
This is an example for our css:
.gb-button-primary:after, .gb-button-secondary:after, .gb-button-primary-neon:after, .gb-button-secondary-neon:after{ position: relative; margin-left:16px !important; margin-top: 0.1em; content: ""; background-repeat: no-repeat; -webkit-transition: all .15s ease-in-out; transition: all 0.5s ease; width:10px; height: 10px; } .gb-button-primary:after{ background-image: url("data:image/svg+xml,%3C%3Fxml version='1.0' encoding='UTF-8'%3F%3E%3Csvg id='Ebene_2' xmlns='http://www.w3.org/2000/svg' viewBox='0 0 5.64 10.74'%3E%3Cdefs%3E%3Cstyle%3E.cls-1%7Bfill:%23fff;%7D%3C/style%3E%3C/defs%3E%3Cg id='Ebene_1-2'%3E%3Cpath class='cls-1' d='m.75,10.74c-.19,0-.38-.07-.53-.22-.29-.29-.29-.77,0-1.06l3.8-3.8c.16-.16.16-.42,0-.57L.22,1.28C-.07.99-.07.51.22.22S.99-.07,1.28.22l3.8,3.8c.74.74.74,1.95,0,2.69l-3.8,3.8c-.15.15-.34.22-.53.22Z'/%3E%3C/g%3E%3C/svg%3E"); } .gb-button-primary:hover::after{ background-image: url("data:image/svg+xml,%3C%3Fxml version='1.0' encoding='UTF-8'%3F%3E%3Csvg id='Ebene_2' xmlns='http://www.w3.org/2000/svg' viewBox='0 0 5.64 10.74'%3E%3Cdefs%3E%3Cstyle%3E.cls-1%7Bfill:%230d0d0d;%7D%3C/style%3E%3C/defs%3E%3Cg id='Ebene_1-2'%3E%3Cpath class='cls-1' d='m.75,10.74c-.19,0-.38-.07-.53-.22-.29-.29-.29-.77,0-1.06l3.8-3.8c.16-.16.16-.42,0-.57L.22,1.28C-.07.99-.07.51.22.22S.99-.07,1.28.22l3.8,3.8c.74.74.74,1.95,0,2.69l-3.8,3.8c-.15.15-.34.22-.53.22Z'/%3E%3C/g%3E%3C/svg%3E"); transition: all 0.5s ease; }
Is there a better way to add icons to button global styles globally?
THANKS und best regards,
Dominik -
Hi Dominik,
How about a Local Pattern? Reference: https://docs.generateblocks.com/article/pattern-library-overview/#local-patterns
Would that work for you?
Dominik
Hi Fernando,
a local pattern would help for inserting the button, but as soon as I want to change the icon, the pattern and global styles do not affect my icon used on the site.
I see. Unfortunately, those are the only two options in GB.
What you can try is a WordPress Reusable Block.
Another approach is to inject the SVG through a PHP snippet instead, but I’m not sure if you’re okay with this too.
Dominik
Hi Fernando,
through php would be a good solution too. is there a snippet for it? -
Try adding
replace-svg
to the class list of the Block.Adding Custom Classes: https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
Then, add this snippet:
add_filter( 'render_block', function( $block_content, $block ) { if ( !is_admin() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'replace-svg' ) !== false ) { $myreplace = 'PLACE SVG CODE HERE'; $block_content = preg_replace('/' . preg_quote('<svg') . '.*?' . preg_quote('</svg>') . '/', $myreplace, $block_content); } return $block_content; }, 10, 2 );
Replace
PLACE SVG CODE HERE
in the code. -
Dominik
perfect – THANKS 🙂
You’re welcome, Dominik! 🙂
