katrinae
Hello.
I have been trying to add two buttons to the top bar, right side.
using the standard button widget, I get one on the right and one on the left of the top bar, which won’t work as I need them both on the right if possible.Now I am trying the custom HTML widget with a WPbakery 50:50 row with 2 buttons
One button is fine, but the other displays the text on two lines.
I have tried changing padding or button style but I can’t get both buttons to display the same way.I would appreciate any help to fix this.
Thank you.This is the code I am using in the custom HTML widget:
[vc_row][vc_column width=”1/2″][vc_btn title=”Course Login” style=”outline” shape=”square” color=”white” size=”xs” align=”right” css=”” link=”url:https%3A%2F%2Fwww.healthandsafetymanager.ie%2Fstgjan2611111%2Fonline-training-login%2F”][/vc_column][vc_column width=”1/2″][vc_btn title=”Client Login” style=”outline” shape=”square” color=”white” size=”xs” align=”right” css=”” link=”url:https%3A%2F%2Fwww.healthandsafetymanager.ie%2Fstgjan2611111%2Fservices%2Fclient-area%2F”][/vc_column][/vc_row]
George
Hello.
There is no indication that your site uses the GeneratePress theme or the Generateblocks plugin, are we missing something? In addition, the credentials you sent us in the private info area do not work.
