krempel-und-co
Hello!
I have an issue with the new global styles when it comes to buttons:
I have the global style class .cstm-button which sets font, background-color, hover effects, text color, padding. So far so good.
When I add a new button the button has the default blue style which doesn’t get overwritten when I add the custom style class .cstm-button as it’s background-color etc. is overwritten by the settings in the “Color”-Section of GB.
I know it’s intended that I can customize the look and feel via css on a element level which overwrites global settings. But with the legacy global styles I could set the button as “primary” or “custom” and the default settings were overwritten.
Am I missing something? Is there a better way to style default buttons in GP/GB and global styles are for those cases where you want to change the default look?
currently you can either Clear the local block styles after adding the global style.
By removing theblock
global style tag:https://docs.generateblocks.com/article/editing-a-global-style/#block
Or my preferred workflow is:
1. style the button as you require in the local styles.
2. create a new Global Style and MOVE the local block styles.
3. now create a Pattern of your Button.Now when adding buttons to your page, use the Pattern.
As the new patterns are same CPT as the core patterns you can even use the / shortcut to find them in the block appender. -
mikedo
This process should be easier. Creating a pattern for a button is a workaround not a solution. We should be able to style the appearance of the default button within the editor.
We have some plans for setting “theme” level styles which is where a default style can be set for a button.
But for now the Pattern method is the best way to go.
