Can I show only sub categories + Aligning button problem
  • The featured images are all different aspect ratios.
    You can select the Image Block, and in its Block settings give it a fixed height value eg. 220px and set the Object Fit to Cover.
    That will resize all the images to the same height. But it may mean some get cropped a little
  • I forgot to say thank you, it helped out. I appreciate the help! Marked as resolved.
  • Glad to be of help!
Viewing 3 posts - 17 through 19 (of 19 total)
