Can Overlay Panels trigger another panel when closed?
    I need to create a popup that opens another one when it closes. Is there an event I can use as a Custom Event trigger?
    There isn’t a built-in for this. It will require custom JavaScript.
    Try follow the steps below:
    1. Add this JS to a hook element, set the location to where the overlay panels will show, set the hook name towp_footer, and replace #gb-overlay-90 with the actual first overlay panel id.
     <script>
    // Put this in a site-wide script (footer, WPCode, child theme js file)
    document.addEventListener('DOMContentLoaded', () => {
        const firstOverlaySelector = '#gb-overlay-90'; // inspect to get exact selector
        const observer = new MutationObserver((mutations) => {
            mutations.forEach((mutation) => {
                if (mutation.target.matches(firstOverlaySelector)) {
                    // Detect when first overlay closes (aria-hidden becomes true or display:none)
                    if (mutation.target.getAttribute('aria-hidden') === 'true' ||
                        getComputedStyle(mutation.target).display === 'none') {
                        // Fire event to open the second panel
                        document.dispatchEvent(new CustomEvent('show-next-panel'));
        const firstOverlay = document.querySelector(firstOverlaySelector);
        if (firstOverlay) {
            observer.observe(firstOverlay, { attributes: true, attributeFilter: ['aria-hidden', 'style'] });
    });</script>
    2. Edit your second overlay panel, and set the trigger type to custom event, set event name to show-next-panel.
    Let me know if this helps!
