Cannot control link hover colour
    I cannot for the life of me find why the links in the footer are dark green when hovered, meaning they are invisible. I’ve changed it to white in every single area I can find, and the dark green is not used in the Customizer anywhere.
    Help!
    Thank you!
    Select the Link Text block, then switch to the Hovered Links selector: https://cln.sh/9RSH8PYGHbJ0BclmLFws
    From there, simply change the text color under the Typography settings.
  • Hi Alvind,
    I have changed every single setting, on the text block, the container, the grid, and nothing is working.
    I don’t have Hovered link in my list?
    See link in Private.
    Thank you!
  • Ah, okay. It looks like the link hover color is being set on the parent Container (gb-element-416f241d).
    Try selecting that Container, then switch to the Hovered Links selector and change the hover color there.
  • Hi Alvind,
    I wish I could say solved but no.. I added white to the hovered link on the main container as well and cleared cache and still the same.. I’m going insane here! Haha!
    Thank you
  • Hi again Alvind,
    I went through every single container and text block and grid again and double checked all options and the grid container suddenly threw up a Hovered links option and there it was!!
    SOLVED! My lord that was painful.
    Thank you.
  • No problem, glad to hear that!
