psrios
HI guys, hope you are well,
Can you please help, I basically not being able to make any CSS changes in the “customize” area, as nothing changes even when I save it.
I have been digging on existing threads to find a solution and tried some suggestions but it did not work.
I contacted the host server to try to fix PHP versions, increase memory, I have turned on and off all the plugins and checked the general area to see if the URLs were matching and nothing works. Can you please give me some help? thanks
It’s likely due to a syntax error in your existing CSS.
Try adding your new CSS to the top of the CSS field and publishing to see if that works, if it does, then you need to check all your existing CSS for syntax errors.
psrios
Hello Ying,
You are right! Do you know any good tool to help me with this by any chance? Thank you!
Patricia.
Not sure, but you can consult your cache plugin’s support on how to avoid this issue in the future by adjusting your cache plugin settings.
psrios
thank you, I will get in touch. Have a great day!
You too 🙂
