Cannot update Generate Blocks Pro
  • I have 9 sites that will not update the GB Pro plugin. I am using Generate One and putting that license into the settings. It says it’s activated and receiving updates but when I try and updated the update fails due to unauthorized. Some of the sites are on Cloudflare and some are not. I have put your ip into an allow list on CF just in case.
    Can you remove the license key and reactivate it, and then try to update GB Pro again?
    Or, if you have auto-update enabled, it should be updated automatically afterward.
    Let me know if this helps!
  • I did that on several sites and it didn’t work. Also I do not use auto update.
    However I did what you asked again and got 7 out of 9 to update. Not sure what the difference is. I am even clearing website cache between adding in the license.
    This is not the first time this has happened. In the past it’s just on one site every few months. But 9 at once is a pain. I use GP/GB on at least 20 sites and always build new ones using that stack.
    Is this a known issue? I have never had this happen this chronically with other plugins.
    What do I do with the 2 that didn’t update? Wait a bit or wait until the next update? Add the plugin again?
  • Can you provide an admin login to the 2 sites that are having issues? I can take a look.
    I have the same issue as hollytga. Also, removing the license key and reactivate it, didn’t help.
    BR,
    Milan
  • Please open a new topic, and provide your site’s admin login so we can take a look at the backend.
  • I tried twice to send the login links. But I can’t see them on this screen. So please let me know if you didn’t get them. Thanks!
  • No, I don’t see the credentials.
    Please edit your first post on this topic and add the site credentials in the private info field. It will only be seen by the support team.
  • Ok I added them. Thanks.
    Working on this internally – it’s a server rate-limiting issue causing the disruption.
    Will report back once it’s fixed. Sorry for the hassle!
  • The issue should be resolved now 🙂
  • Great. Thank you.
  • You are welcome   🙂
  • Everything is fine now. Thank you and cheers.
