Can’t change a pattern title
    I need to change a local pattern title, is it possible? I don’t see the standard way in the pattern overview (quick edit) nor in the pattern detail (there is no title). I’m aware I can copy the content and create a new pattern but…
    Thanks, Alena
    There’s currently no intuitive way to change the Local Patterns title. I’ve heard WordPress will address this in version 6.6.
    As a workaround, edit the pattern, click the three-dot options on the top right, and select Code Editor. From there, you can change the title.
  • Thank you, it works! Such a trick!
  • You’re welcome!
