Search for: Can’t disable version 1 blocks Bernhard July 21, 2026 at 8:42 am Hello, in the Generateblocks settins page, switching the toogle “Use version 1 blocks” to off and saving it says settings saved. Reloading the page, the toggle is on again. In the editor I see the v1 blocks. Ying July 21, 2026 at 8:52 am Hi there, Do you have any custom PHP snippets that might be affecting the setting? If you are not sure, can you disable all plugins except GB, GB Pro? And also switch to the parent theme to test. Let me know how it goes! Bernhard July 21, 2026 at 9:32 am add_filter('generateblocks_use_v1_blocks', '__return_true'); was in the functions.php. I removed it and now it works. Ying July 21, 2026 at 9:45 am Glad to hear that 🙂 Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic.
