Can’t edit posts
  • Hello, it seems that I lost the ability to edit posts. When I click ‘edit’ post, the window opens up, but it’s empty. Please see more info in the second window.
    Please can you let me know how to fix it? Thank you
    It requires login to see the URL you provided.
    Can you share the admin login so we can see the issue?
    And can you also try to disable all plugins to see if any plugin is causing the issue?
  • Hello, I’ve disabled and tested almost all the plugins and nothing has changed.
    Can you please provide me with your email address so that I can create a temporary admin login for you?
    Thank you
  • You can use a made-up email, WP does not check that.
  • Hello, please find login details in a second window.
  • I logged in and checked the post editor, it seems to be working fine:
    https://app.screencast.com/qJbBnem4zXWPp
    Can you try login with the account you created for us?
    If it still doesn’t work, can you try using an incognito window in case your browser extension is the culprit?
  • Hello, thank you for checking it out! Indeed, I can edit while in incognito mode.
    Do you know what I can do to fix the issue with my browser? I use Chrome
  • Disable all your browser extensions and try to log in.
    If it works, then enable them one at a time to check which one is causing the issue.
    Also make sure you clear the browser cache and cookies.
  • All right, thank you!
  • No Problem 🙂
