Can’t figure out why the 2nd box is smaller
  • Hi GP Team
    I am starting to use Flex Containers here. This resource thing is amazing.
    I am struggling to find a way to keep the “Book a CALL” CTA on the bottom of the 3 child containers and aligned themselves.
    You will see that I even tried to define a minimum height of 600px, but It didn’t work.
    Could you give me some light ?
    Thank you so much
    1. select the 3 child containers, set justify-content to space-between, min-height to 100%.
    2. select the parent container, set align-items to default.
    3. select the parent container of each CTA button, and set margin-top to auto.
  • Hi Ying,
    Great. The only thing that still weird is the Column 3, the “Boost Your Social” is not aligned with Column 1 and 2.
    Is this because the Title “Fast Results” has 2 lines?
    ..the “Boost Your Social” is not aligned with Column 1 and 2.
    To align it, reduce the margin-bottom of the container wrapping the icon and headline in the third column to around 40px.
  • thank you
  • You’re welcome
