Zutzut
Hello team,
On a new wordpress, I’m trying to install the starter https://gpsites.co/niche/
Following the instructions, I go to appearance >> Generatepress >> LibraryThe problem is that the display loads non-stop (please see https://i.imgur.com/97v8HQV.png), so I can’t select my theme. Is there another way to install it?
Thanks !
see the following article and follow the steps under Constant Loading
https://docs.generatepress.com/article/site-library-unavailable/#constant-loading
Zutzut
Awesome, thanks David, it did works 🙂
Glad to hear that!
Zutzut
My apologies David, I’m reopening this post. Maybe I got carried away a bit early 🙂
I manage to see the starter themes now, but not to install it, it grinds non-stop when importing content, please see https://i.imgur.com/FFfuJ8v.png
I tried to deactivate all my plugins to keep only GP, but it does not work either.
Is there any other way to install this content? -
Does the issue only happen to this specific site template or all of them?
Zutzut
Hi Ying,
Unfortunately all of them !
Can you go to tools > site health > info > server, can you check if the server configuration meets the suggested values?
- PHP max input variables 4000
- PHP time limit (max_input_time) 1200
- PHP memory limit 512M
- Max input time 600
- Upload max filesize 300M
- PHP post max size 512M
