Can’t Remove Extra Image Padding
  • Hey Guys,
    I created a block element (with one container and one image) and hooked it below the header (generate_after_header) to display a thin multi-colored line. The line should be flush with the hero banner, however, even with everything set to 0px padding and 0px margin, I am still seeing excess padding – no idea why.
    Here’s a screenshot – https://imgur.com/a/AY9TBjg
    I’d really appreciate some help to solve this mystery.
    Thanks guys
    Mozez
    Can you try this?
    1. Add a CSS class to the image block, eg. true-height.
    2. Add this CSS:
    figure.gb-block-image:has(.true-height) {
        display: flex;
    Let me know if this helps!
  • Hi again Ying,
    I’m following up on this same topic from last week.
    The CSS you gave worked great! The multi-colored image looked perfect when I hooked it into the header and footer. However, I also need to display the image on other sections of the page but when I add it as a regular image it shows super tiny.
    I wonder if there’s a way to hook it to:
    A) Hook it to certain parts of a page
    B) Fix the image
    Please see the link to the screenshot and site below.
    Thanks so much
    the issue comes from the <figure> element that wraps the <img>
    Its a content element so it inherits typography styles such as font-size and line-height from its parent.
    As theres no way ( currently ) to remove the figure you can try this CSS:
    figure.gb-block-image {
        line-height: 1;
    Which will reduce the line-height so its identical to the font size , which will remove the gap below the image.
    IF need be you can do this:
        line-height: 1;
        font-size: 0;
    Which will make the figure the exact height of the image.
    But if any images have a caption you must make sure the caption has its own font-size.
