Jack Huang
Hi, team,
In the changelog of GenerateBlock (free version), you mentioned that since 2.0, there are new elements below:
New: Element block – replaces the Container and Grid blocks
New: Element blocks comes with Container and Grid variations in the block inserter
New: Text block – replaces the Headline and Button blocks
New: Text blocks comes with Headline, Text, and Button variations in the block inserter
New: Query block – replaces the Query Loop block
New: Looper block – replaces the Grid block inside of the Query block
New: Loop Item block – replaces the Post Template (Container) in the Query block
New: No Results block – add content that displays if no Query results are found
New: Page Numbers block – add page numbers for pagination in your Query block
New: Shape block – add any SVG shape to your pages
New: Media block – replaces the Image blockThe problem is that I still can only see the old elements, even with a new install of the latest version. Do I need to do something to turn it on? Thank you.
Hi Jack,
You can find more details in this documentation:
https://learn.generatepress.com/blocks/block-guide/generateblocks-1-x-to-2-0/#ver2 -
Jack Huang
I see, thank you Alvind!
No problem! 🙂
