Can’t you let the ‘progress bar’ come into the container??
  • Can’t you let the ‘progress bar’ come into the container??
    For better understanding, I will attach the image and website address.
    https://imgur.com/a/ySXop1e
    https://speakpartner.kr/%ed%85%8c%ec%8a%a4%ed%8a%b8-%ea%b8%80%ec%9e%85%eb%8b%88%eb%8b%a4/
  • What is the hook you are using to insert the bar?
    Change it to inside_site_container, and add this CSS:
    .progress-container {
        position: sticky !important;
  • When I entered the code, the problem I originally told you about has been solved.
    But the problem is that the progress bar was stuck in the header, not the navigation. What should I do?
    I’m attaching the image below.
    https://imgur.com/a/ZeH3Qdv
  • Where can I see this issue?
  • https://speakpartner.kr/%ec%9d%b4%ed%9a%a8%eb%a6%ac-%ec%98%81%ec%96%b4%ed%9a%8c%ed%99%94-%ec%96%b4%ed%94%8c-%ec%8a%a4%ed%94%bd-speak/
    This is the url above. Is there a way to get the ‘Progress bar’ to attach to the navigation?
    you can try the method provided here for adding a Reading Progress Bar
    It gets attached to the bottom of the navigation including when it is sticky
  • With reference to the attached content, I have removed all HTML, CSS, and SCRIPT related to the existing progress bar.
    By the way, where should I activate ‘GP Sticky navigation’?
    It is currently fully initialized.
  • 1. The code below has been registered as ‘hook – generate_inside_navigation’.
    <script>
    window.onscroll = function() {updateScrollPercentage()};
    function updateScrollPercentage() {
      var winScroll = document.body.scrollTop || document.documentElement.scrollTop;
      var height = document.documentElement.scrollHeight - document.documentElement.clientHeight;
      var scrolled = (winScroll / height) * 100;
      // Set CSS variable
      document.documentElement.style.setProperty('--scroll-percentage', scrolled + '%');
    </script>
    2. Then, I added the css code below in the customization.
    <style>
    :root {
    –scroll-percentage: 0; /* Default value */
    .navigation-stick .inside-navigation {
    position: relative;
    .navigation-stick .inside-navigation:after {
    content: ”;
    pointer-events: none;
    position: absolute;
    left: 0;
    bottom: 0;
    height: 4px;
    width: var(–scroll-percentage);
    background-color: #0092FF;
    </style>
    3. However, the following error occurred. (Image attached)
    1. (Can’t save with invalid setting of 1)
    2. (Markup is not allowed in css)
    https://imgur.com/a/5fbh9OR
  • Oh! I put them all in ‘elements’ and it’s solved!! Thank you!!
  • Glad to hear that
