chrisvan
We have installed the GenerateBlocks pro 2.5.0 with GenerateBlocks 2.2.0
I can use blocks like Accordion or Tabs, but the Carousel block cannot be found.
Any idea why it is not available?
KR,
Chris -
Hi Chris,
Can you go to dashboard > generateblocks > settings, check if you are still using v1 blocks, if so, toggle it off, then your new blocks will be v2, which includs carousel block.
Let me know if this helps!
stencil
Hi there, I am having the same issue but when I go dashboard>generateblocks>settings all it shows me is global max width and CSS print method, no version to toggle.
Any guideance? This is a new site/install.
I really want to be able to use the new carousel block.
Thank you!
Vicky -
George
Hi Vicky,
What is the version of GenerateBlocks Pro you are using? Make sure you are using the latest 2.5.0.
stencil
Hey George,
New install – so all up to date…
GP Premium Version 2.5.5 and GenerateBlocks Version 2.2.1
Am I missing something?
George
Yes, you need the GenerateBlocks Pro version!
stencil
Assuming that is not included in Premium then since I don’t have it?
George
GP premium is the plugin that extends the free GeneratePress theme’s functionality. GenerateBlocks Pro needs to be purchased separately or through the GeneratePress One package.
stencil
Thank you for clarifying! It is a little confusing with all the packages now.
