Carousel Block
    How to I get the logo image to properly fit inside the image container? Right now the sides are cut off. Also, is there a way to have a set amount of lines, then a “Read More” button that expands the cards so you can read the entire review? Like an accordion function.
  • So I found new icon images, and those seem to work…just need to know if there is a “read more” option in the block…thanks.
    There isn’t a native solution for that, unfortunately. To achieve it, you would need to use a custom JavaScript implementation.
  • ok thanks.
  • No problem.
