Carousel going in the opposite direction (right rather than left)
  • Hi team!
    Loving the new carousel block! My client has requested it going in the opposite direction, can I make that happen? So sliding to the right rather than to the left.
    Thank you!
    This is not currently possible from the block settings. The Carousel block does not expose a direction or reverse option yet.
    If you’re referring to the arrow controls, you can use a Previous control instead of Next, or swap the control icons.
    If you mean reversing the autoplay slide direction, that would require custom JavaScript.
  • Hi Alvind,
    Ok thank you, I’ll ask the client to reconsider this one. And yes I meant reverse the slide direction.
    Thank you as always!
  • Sure, no problem!
