Carousel images on infinite loop not loading
    On the page below I’m using the carousel block from Generate Blocks, and the images seem to be having a hard time loading for the infinite loop (when you scroll to the right); I’m wondering why this might be?
    Elisabeth
  • Hi Elisabeth,
    I can see the issue on your site, but I can not replicate it on my site.
    Can you disable all plugins except GB and GB Pro to test?
  • The images are all loading correctly now on my site; is that what you see on your end as well?
    Elisabeth
  • Hi Elisabeth,
    From my end, infinite scroll works when dragging the carousel to the right with the mouse but fails on the opposite direction.
  • Ok, I de-activated all plugins except for Generate Blocks, Generate Blocks Pro, and GP Premium. To me both carousels seem to be working just fine (see video below); this is how they were working both before and after deactivating the carousels.
  • They both look fine to me.
    Are other plugins deactivated currently? If so, can you try activating them one at a time, to see which one is causing the issue?
  • I just re-activated everything and it seems like it’s still working fine. Strange. As long as you’re not seeing any issues, I think this is resolved.
  • Glad to hear that 🙂
