MarthaMakesYourContent
Hi lovely Generate team,
I’ve been really excited to use the new carousel feature on my latest website build. (https://theretreatreflex-10f610885i.live-website.com)
Everything looks fantastic on desktop but I am having trouble optimising for mobile. I have two carousels:
1.) Reflexology Treatments by concern
This one is a biggie. The idea is that the viewer gets two treatment suggestions per concern. I have reduced the 3 columns on desktop to 1 column, 3 rows on mobile. The remaining problems are:
– excessive padding above and below the carousel that I can’t seem to shake
– i need to change the layout of the mobile specific cards so that they are shorter so that the reader can see the concern and treatment options at the same time. I am thinking a narrow photo on the left of the box, the tag, treatment name and description in a second column beside and the duration, price and book button below and across the two columns. Of course I am open to hearing your thoughts.
– as you click through the carousel, things look even messier. HELP! 🫶2.) Benefits of Reflexology
– I want one card to appear per slide, centre aligned
– there are a couple of ‘ghost slides’ at the end that I can’t make sense of.I have provided login details below. Thank you so much as usual!
To have the image on the left and text on the right, you need to wrap the text with a new container.
I don’t think it’s possible based on your structure. As each slider includes the title and 2 cards.
I think the only solution would be hide this section on mobile, and build a new carousel only for mobile.
Hi Ying,
Thank you for your quick reply, as always. I think in this case, our wires got crossed a little bit.
I have recorded a short video to show you exactly where I am stuck: https://www.loom.com/share/d329b2611b0842bca13b6bc92570793d
Incredibly grateful for your help. I have spent all day trying to fix this and I am getting nowhere.
1. You will not be able to remove the “paddings” you are referring to, nor will I.
The spacing is occupied because the entire carousel is a whole unit, it will occupy the space to accommodate all carousel items, so if there’s one extra long, then the entire carousel will be the same height.
I also suggested creating a new one for mobile only.
2. Can you wrap a container for the text, so I can see what issue you have?
3. For the 2nd carousel, you’ve set Slides per view to 3, so it would show 3 on mobile as well. There is no responsive setting for it currently. I would recommend hide it on non-mobile devices, and create a new one for mobile and set the sliders per view to 1.
Hi Ying,
I had already rebuilt both of these carousels for mobile. I am sending a screenshot of my editor list view. The carousels in question are Treatments for Concern MOB and Benefits MOB.
1. I understand this in terms of the padding at the top of the carousel but there’s also a huge space below it that I can’t make sense of. Can you help me get rid of that? And is there a way to remove the spacing at the top for the mobile version? If there is not, we might get away with it, as long as the bottom spacing goes.
2.) I have duplicated one of the cards and moved it to the bottom of the page to try and build it out the way I need it. I am sending a screenshots of what I am trying to achieve and where I am stuck. I can’t even seem to get the basics right on this one. The container holding the image and the wrapped text isn’t full width (although I’ve set it to 100%), so the content that should be below it, sits beside it.
3.) I think you looked at the desktop version of this. I have attached screenshots of my carousel settings for the mobile version, which is set to slides per view 1.
All my screenshots are in this folder: https://drive.google.com/drive/folders/1m7olhJMi36Ob8SXCEWwTeAeHFgZnYtqS?usp=sharing
Thanks so much for your help. I wouldn’t ask if I wasn’t at the en of my tether.
1. I do not see a carousel on mobile for the About section. Did you add it?
2&3. You have set a
max-widthfor the carousel items in the mobile benefit section, it conflicts with the calculation of the JS, I’v changed them to 100%, so only 1 item will be shown at a time on mobile, please check.
