It seems my iPhone is not autoplaying the carousel block. Works fine on desktop and Chrome inspect Mobile. Just not my iPhone. Provided login link below. Any ideas?
ok, I found the issue. It’s the Settings > Accessibility > Motion > Reduce Motion toggle in iOS. By default, I think this is set to ON. Good accessibility means I also adhere to this setting when I implement fades and slides. If it’s on, iPhone users see no subtle animation, I am ok with that. But for a carousel, I wonder how we should move forward.
If this is indeed the cause, I do think we need to have a conversation about how to best make all of this work. I want to adhere to the client’s preferences but use case here is for the carousel to scroll through partner logos. There must be a way to make this work and adhere to accessibility best practices for mobile?
Hi Ian,
Are you referring to the logo slider at the bottom of the homepage?
If so, it works on my iPhone. I would suggest checking it on other devices to confirm.
i do not think so. It’s default to off.
Hi Ying, yes. See my reply above. What do you think?
I do not think there’s anything we can do, unfortunately!
Thx Ying. Glad I was able to find the cause. On one hand, I am very happy GP code is as deliberate as my own to abide by accessibility rules. But it does make me wonder how I can get a scroll of partner logos on mobile. I guess this is the same conversation with the client explaining our code is abiding by user preferences on their phones.
If you or anyone on your team have any suggestions, I am all ears. Thx Ying!
Exactly!
webfresh
Hi Ian
I had a similar problem with infinite loop not working on windows PC, where the ‘reduce motion’ setting was turned on.
Alvin had a good explanation of what was happening and suggests that they are hoping to find a solutionhttps://generate.support/topic/gb2-5-carousel-infinite-loop-not-working-on-firefox/
Hi webfresh,
Thanks for the link and info! Totally makes sense.
So you and I have confirmed this issue. Let’s see if there is a real world solution.
Cheers!
Add:on: bumped the other thread and linked added to this one just in case it helps for troubleshooting
