Carousel: radius lost on transition
    Please take a look at this page:
    https://fadomagazine.com/fado-houses/fado-houses/porto/fado-maior-do-porto/
    I’m having an issue with the GenerateBlocks Carousel block. I’ve applied a border-radius to the images, but it disappears (returning to sharp corners) during the slide transition animation. It only reappears once the movement stops.
    Key details:
    Context: This carousel is loaded via a GP Element (Content Template).
    The Issue: overflow: hidden seems to fail during the CSS transform/translate animation.
    What I’ve tried: I applied border-radius and overflow: hidden to both .gb-carousel-item and the img using !important, along with hardware acceleration (translateZ), but the flicker persists.
    Goal: I need the corners to stay rounded (4px on desktop, 12px on mobile) consistently during the entire animation.
    Could you please check if there is a specific fix for this?
    Thank you!
    Can you try applying the border radius to the Carousel block itself?
    Sure!
    It workek, forget that there were severeal level of boarders, container, carousel, etc.
    Thanks.
  • No problem! 🙂
