shamrick
Context:
Standard WP Posts utilizing the Categories, Tags, and a custom taxonomy called ‘Message Topics’ (created in ACF) in the following way:
Categories = Conference Year – using much like the name of a podcast. Think 3-5 different podcasts
Tags = Speaker name – much like a podcast host
Message Topics – topic or topics assigned to each message for 1) topic search and 2) filtered display on the main search pageThe layout I’m trying to achieve would be similar to a streaming service or podcast player
Currently I’m trying to figure out 2 things:
1. how to use the post loop to return to not just return a carousel of posts but a carousel of tags (speaker names) and custom taxonomy (Message Topics). I can get it to return the posts, but not the taxonomies themselves. Perhaps it’s not made to do that. (One taxonomy per carousel block)
2. Size each container in the post loop to be perfectly square (1:1 ratio). I’ve tried setting min and max width values in pixels but they aren’t exactly coming out right. -
1. Query loop can only show posts or custom posts, it can not loop through taxonomy terms. You can try WP’s tag cloud block or category list block, for custom taxonomy, you will need to write custom PHP code to show them.
2. The grid container width is set to 150px, however, it includes 20px padding-left (horizontal gap), so your container height should be 150px – 20px = 130px to make a perfect square.
shamrick
Thank you. I wondered if that was the case.
By chance would it be possible to hook into the query loop and do that with some custom php using the classes feature on the grid block within the query loop?
Yes, you can use the
render_block
filter to output any content you want.Here’s an example for render GB’s headline block:
add_filter( 'render_block_generateblocks/headline', function( $block_content, $block ) { if ( !is_admin() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'my-custom-class' ) !== false ) { // do your custom function here // generate $block_content } return $block_content; }, 10, 2 );
shamrick
Thank you. I’ll try it out.
Is that a better approach to the query loop than what David suggested here: https://generate.support/topic/query-loop-logic-and-sorting/#post-110187
It’s a different topic, that is to alter the posts of the query loop, not adding content to the query loop.
shamrick
As I’m working on it, and for clarity’s sake, I’m targeting ‘generateblocks/query-loop’ but placing the class on the Grid block that’s within the Query Loop, correct?
thats correct.
