Categories Hierarchy
  • johnottomagee
    Hello GP Support !
    I have Generate Blocks Pro.
    For my posts I have three categories:
    Country, Topic, Subtopic.
    For example: Germany (country), Communication (topic), Small Talk (subtopic).
    Those three categories are presented at the
    bottom of a post alphabetically:
    Communication, Germany, Small Talk.
    Is it possible to have categories presented
    based on hierarchy: Germany, Communication, Small Talk?
    Thanks.
    John
  • Hi John,
    This is possible if the categories have an actual parent/child hierarchy:
    Germany – no parent
    Communication – parent: Germany
    Small Talk – parent: Communication
    Then add this PHP snippet:
    add_filter( 'get_the_terms', function( $terms, $post_id, $taxonomy ) {
        if (
            is_admin() ||
            'category' !== $taxonomy ||
            ! is_singular( 'post' ) ||
            ! is_array( $terms )
            return $terms;
        usort( $terms, function( $a, $b ) {
            $a_depth = count(
                get_ancestors( $a->term_id, 'category', 'taxonomy' )
            $b_depth = count(
                get_ancestors( $b->term_id, 'category', 'taxonomy' )
            // Alphabetical order when terms have the same depth.
            if ( $a_depth === $b_depth ) {
                return strcasecmp( $a->name, $b->name );
            return $a_depth <=> $b_depth;
        return $terms;
    }, 10, 3 );
    This changes the output to:
    All three categories must remain assigned to the post if you want all three displayed. If they are three unrelated categories rather than a real parent/child chain, WordPress has no hierarchy it can use for sorting. In that case, separate taxonomies for Country, Topic, and Subtopic would be the more reliable structure.
  • johnottomagee
    That was fast.
    Thanks, Alvind.
    I did not work.
    Or more likely I got something wrong.
    See:
    https://understand-culture.com/ucstage/?cat=3375
    I have the Plugin Code Snippets Version 3.9.6.
    Could the problem be that I am working
    on a staging site?
    John
  • Hi John,
    I can not see the link without logging into your site.
    Can you provide an admin login?
  • johnottomagee
    Hello Ying,
    It’s been ages.
    I hope you’re doing well.
    I just created an admin:
    [removed by admin]
  • Haha I’m great, thanks for asking 🙂
    The code is working, but it is intended to only work on a single post, not the archives.
    Do you want to change the order for archives and blog as well?
    If so, the code can be updated to this:
        if (
            is_admin() ||
            return $terms;
            $a_depth = count( get_ancestors( $a->term_id, 'category', 'taxonomy' ) );
            $b_depth = count( get_ancestors( $b->term_id, 'category', 'taxonomy' ) );
        return $terms;
    }, 10, 3 );
  • johnottomagee
    That worked.
    Perfect, Ying.
    Thank you !
  • You are welcome   🙂
  • johnottomagee
