Category Description – Explore Theme
  • I cant find anything on this. I’m trying to add a description to the category but it’s not showing after the content is saved for the description in the post area. It’s just blank on the category page, see direct example link.
    Oh and would I be able to add buttons into this description if I created the “description” with the element option? if so how would I use an element options to show a description with buttons on the category I’ve provided an example of?
    Best Regards,
    You will need to add a description for your categories in order for the description to show up. You can edit existing categories to add a description on Post > Categories.
    To add a button, you will need to do that in the Archive Hero element. Just add a new button block, and if you want, you can use the dynamic setting to set where the button links to dynamically.
