Category Landingpage
  • Hi, I want to create a category landing page like the website I have linked to in the private section. How can I do this? Have they used something like a query loop?
    Greetings Kathrin
    You can create a block element – loop template, and add a query block inside, style it, and toggle the Inherit query from template option, so it will load the posts of the category.
  • Topfgartenwelt
    Ok, but is it possible to only show about 10 posts per page and the 11th post is loaded on another site?
    And where I can find the inherit from … ?
    Greetings Kathrin
  • What do you mean loaded on another site?
    Check the screenshot for the option:https://app.screencast.com/puICt7FkqwUA6
  • Topfgartenwelt
    I have found it 🙂
    I mean that each page should only show 10 posts in the query loop and then there should be another page with 10 posts
    page 1: 10 posts, page 2: 10 posts 🙂
    And is it possible to center the H1 on that category pages?
    Greetings Kathrin
  • You can set posts per page to 10 at dashboard > settings >reading.
    Yes, you can include the h1 title in the block element – loop template. You can use a GB headline block, and dynamically set it to archive title, or use a WP archvie title block.
  • Topfgartenwelt
    Ok and how can I style the h1 from that category pages?
    Greetings Kathrin
  • Topfgartenwelt
    I have used a GB headline block and set it dynamically to title but I can’t the option archive title.
  • Archive title is available for GB V2 text and headline block:
    https://app.screencast.com/LsOTS6v8owe5g
  • Topfgartenwelt
    I have made the latest updates but I don’t have a pro version of Generate Blocks. I have version: Version 2.0.1. But Archive title is no part of it.
  • You might be still using v1 block, go to generateblocks > settings, you can toggle off the v1 option.
  • Topfgartenwelt
    Oh thanks that worked. The Archive Title should be an H1 in the end. Is that ok or do I have two h1 titles in the end?
    After changing the versions from Generate Blocks… is this effecting older heading blocks?
    Greetings Kathrin
  • Yes, archive title should be H1.
    You have 2 options:
    1. add the archive title to a block element – page hero, and it has the option to disalbe title.
    2. still add the archive title to the block element – loop template if that’s easier to manager, then create a block element – page hero with no content in it, just enable the disalbe title option for all archives.
    No, existing v1 block will stay as v2 🙂
  • Topfgartenwelt
    At the moment I have set the GB Heading to H1. But now I need another Block Element set to page header and disable the title option for all archives? Am I right?
    Greetings Kathrin
    That is correct. Just toggle “Disable Title” on this element and set the location to “All Archives.”
  • Great! Thank you!
Viewing 16 posts - 1 through 16 (of 17 total)
