Category Menu Doesn’t Link to Category Posts
  • I’ve updated my menu and now none of my menu items link to categories. Any ideas what’s preventing this from working like it used to?
  • You are using a block element – loop template, in the element, select the query loop block, and check if the Inherit query from template option is enabled.
    if not, enable it.
  • When I toggle that, my menus work but my main page is not following my element template.
  • Your homepage is a static page; does it have the same loop template as well?
    If so, exclude it from your loop template.
  • I believe I’ve set everything right.
    Static Page
    Homepage: Blog
    Posts page: Posts
    Block Loop Template Location: Page – Blog
    Exclude: Front Page
    Inherit query from template. Now homepage is just a comment form
    Menu items work (but need to fix pagination at bottom).
    Any ideas on where the hiccup is?
  • Issue is still on-going. Any advice?
    Try changing the location for the Block Loop Template to All Archives.
  • I’ve made that change and homepage still displays only a comment form in the main area
  • Your homepage is set to a static page, do you have any content on the page?
    Or do you want the homepage to display all your posts?
    If so, go to dashboard > settings > reading, and set Your homepage display to Your latest posts.
  • Got it! Thanks so much!
  • You are welcome   🙂
