Hi all,
I’m a little confused as I think my previous freelancer edited my category pages with Elementor.
I wanted to actually convert the design changes with “Post Category” elements instead.
For e.g. https://easternmama.com/category/mamas-recipe/4-6-months/
When I look at the page, I can see that there are 3 elements (header, footer and a post category (content template) on that particular category page.
So, when I go to elements >>> post category, I can’t seem to be able to edit it as what’s within the post category is different from what I see on the layout of the category page.
If the changes were indeed done in Elementor, how do I transfer the changes into an element? Or do I have to redesign the element from scratch?
Hi Mxho,
As I can see, the previous developer used Elementor to create the template and it is overriding the new design you have created using Block Element – Content Template.
So first, you need to disable the Elementor template design which comes under Template > Saved Templates, and look for “mamas-recipe” and convert it to a draft if you don’t want to delete it.
Hi Fernando,
thanks for the help. I have disabled all the Elementor templates.
Now, for my category page e.g https://easternmama.com/category/mamas-tips/chinese-herbs/
I tried to assign my right sidebar to all category post archives. But it isn’t showing in the Chinese herb category.
those archive pages are currently set to display the Left Sidebar ( in Customizer > LAyout > Sidebars -> Blog ) you would need to change that to Right Sidebar layout.
Ah, got it.
Also, I think that I might not have understood how post content template work. The changes that I put in wp editor applies to the style of how each blog post is shown within the category archive page.
However, what if I want to add say this colored area: https://i.imgur.com/pfsrmpQ.png into my category archive page.
How do I do that?
You can use a block element – hook to insert this content, set the block element’s location to
category archive
, and then choose a hook name from this visual hook guide:
https://docs.generatepress.com/article/hooks-visual-guide/#posts-page -
Hi Ying, thanks for the answer.
I have been able to add in a block element – hook (after-header).
So is there a way in which I can add 2 hook locations (e.g. after-header and before-footer) in 1 block element? This is so that I can create a layout template for say “Chinese herbs” categories and then other layout template.
Also, what if I want to change the position of the category archive page’s title and description to say at the before-footer location. How do I go about doing that? https://i.imgur.com/gSZUrZa.png
No, you can not. you will need 2
block element - hook
for different hook names.what if I want to change the position of the category archive page’s title and description
In this case, you need to create a block element – loop template, what’s in the element will replace the entire loop of the archive page, including the title, description and the posts.
https://docs.generatepress.com/article/block-element-loop-template/You will need to add a query loop block in order to show the posts.
Thank you, this solved my problems on this matter.
