Centering container with custom html block
  • Hi there , see the link in private information.
    I have a mailchimp block embedded in the site footer using the custom html block. When I’m logged in, using a laptop, it appears correctly spaced in the center even when shrinking the window down to a small phone size. However on an actual iphone the block is not centered, but to one size and overflowing slightly.
    It’s based on one of your template sites. How can I get this mailchimp block to always be centered?
    All help appreciated
    Can you select the parent container of the form (gb-element-48aade2d), and set display to block on mobile?
    Then add this CSS to override the form’s width, which has been set to 400px.
    #mc_embed_signup {
        max-width: 100%;
  • Thank you.
  • You are welcome   🙂
