Christian
Hi GP/B team.
How can I change the “gb-submenu-toggle-icon” to another .svg in the new navigation block?
Thanks already for help.
Christian
Hi Christian,
I don’t think there’s a built-in way for this, unfortunately.
Christian
Okay. Is there a way to solve this with code in the functions.php, similar to original navigation with the generate_svg_icon_element?
Yes, you can use the general WP filter
nav_menu_item_title, GB uses the same filter to add the default dropdown arrow:add_filter( 'nav_menu_item_title', function( $title, $menu_item ) { if ( false === strpos( $title, 'gb-submenu-toggle-icon' ) ) { return $title; } $old_svg = '/<svg class="gb-submenu-toggle-icon.*?<\/svg>/s'; $new_svg = '<svg class="gb-submenu-toggle-icon" viewBox="0 0 24 24" aria-hidden="true" width="1em" height="1em" fill="currentColor"> <path d="M7 10l5 5 5-5z"/> </svg>'; return preg_replace( $old_svg, $new_svg, $title ); }, 20, 2 );Just update the SVG code for
$new_svg. -
Christian
Thanks, that’s great. 😉
Is this also working with the navigation arrows in the new carousel block?
No, that’s different, it’s not a menu item.
Christian
Ok. Thanks again for your help! 😉
No Problem 🙂
