Change close icon
    Searching the GP documentation, I found a snippet to change the default icons.
    I have used this one to change the menu icon and close:
    add_filter( 'generate_svg_icon_element', function( $output, $icon ) {
        if ( 'menu-bars' === $icon ) {
            $output = '<svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 24 24" width="24" height="24" fill="none">
        <path d="M4 8.5L20 8.5" stroke="currentColor" stroke-width="1.5" stroke-linecap="round" stroke-linejoin="round" />
        <path d="M4 15.5L20 15.5" stroke="currentColor" stroke-width="1.5" stroke-linecap="round" stroke-linejoin="round" />
    </svg>';
        return $output;
    }, 10, 2 );
        if ( 'close' === $icon ) {
        <path d="M15.7494 15L9.75 9M9.75064 15L15.75 9" stroke="currentColor" stroke-width="1.5" stroke-linecap="round" stroke-linejoin="round" />
        <path d="M22.75 12C22.75 6.47715 18.2728 2 12.75 2C7.22715 2 2.75 6.47715 2.75 12C2.75 17.5228 7.22715 22 12.75 22C18.2728 22 22.75 17.5228 22.75 12Z" stroke="currentColor" stroke-width="1.5" />
    </svg>';
        return $output;
    }, 10, 2 );
    The menu one is working, but the close icon is not working.
    You can see it live on this site: https://blockagency.co/
    Could you help me to fix this?
    Try using the snippet provided here instead:
    https://docs.generatepress.com/article/generate_svg_icon/
  • Hello Alvind,
    Those scripts seem to have some bugs.
    I tried both of them, and they really seem to work half-heartedly.
    One only changes the menu icon, and the other only changes the slideout menu close icon.
    Have a look: https://take.ms/arff9
    Can you help me with this?
    in the second part of the code:
    Change it to:
    if ( 'pro-close' === $icon ) {
  • Hello David,
    Do you mean the snippet I used before?
    This one:
    </svg>';
        return $output;
    }, 10, 2 );
    </svg>';
        return $output;
    }, 10, 2 );
    I tried to do it but nothing really happens.
  • Hello Ying,
    I had already tried that, but the last snippet has some bugs:
    – It only changes the slideout close icon.
    – It does not change the menu icon.
    – When you click, during the slideout transition, it shows another close icon.
    Take a look: https://take.ms/TR4fK
  • Try changing this line if ('pro-menu-bars === $icon) to if ('menu-bars' === $icon)
  • Hello Ying,
    That worked great, thank you very much!
  • Glad to hear that 🙂
