WeeWilliam
I want to change the date from light grey to black in the comments. I tried several ChatGPT CSS additions that did not work and I don’t see anywhere else to change. I can change it in inspector but I am lost otherwise.
Try this:
.single #comments time { color: black; } -
WeeWilliam
Hello, that didn’t work either..It didn’t change in customizer. Went ahead and published, cleared caches, hard browser reset, ingonito.
I tried this one before from Chat too, that didn’t work.
.comment-meta time {
color: #000000 !important; /* Forces the color to black */
Can you add the CSS to the top of your CSS field?
I think you might have some “bad” CSS that prevents all CSS below it from working.
WeeWilliam
That did it, thank you! Any way to locate the “bad” css that would cause that. I had an issue ahile ago that a css addition did not appear to work. (I gave up on that one)
Glad to hear that 🙂
You can use a tool like this to test your CSS:
https://jigsaw.w3.org/css-validator/ -
WeeWilliam
Ok great, Thanks.
No Problem 🙂
