Sarina
I had sometime back added some headings in a different color but because of contrast issues wanted to convert all of them to black. Because I randomly changed them, manually changing them is not an option.
What is the best practise for that
I tried chaging the color through customiser – typography color = but it doesnot change the color properly = wherever i checked it didnt change.so I added this code in the additional css editor
/* Apply softer black color to all headings */
h1, h2, h3, h4, h5, h6 {
color: #333333 !important; /* Softer black with priority */
This seems to work.is this the best practise?
yes the CSS method is the best way to go. Just be mindful that you won’t be able to edit individual heading colors ….
Sarina
I have not been able to change the font color this way
I added this code to the customiser – additional code –/* Apply softer black color to all headings */
}Earlier i was using it alright with just the h3s but now i added all the other ones and now it is no longer working. is the code wrong?
The code looks ok.
Can you try clearing any caches on the site ? -
Sarina
I have cleared the cache, and cleared the css cache too
Still not changed -
I do not see this CSS in your customizer > additional CSS, how did you add it?
The highlighted CSS is the last piece of CSS that I can see in the addtional CSS field:
https://app.screencast.com/xh7BYS6Q9A0O2 -
Sarina
Sorry I had removed it for some time
Have you re-applied the CSS?
Sarina
yes
Awesome. So I assume there are no more issues?
