esperandzo
Hi!
I’m experiencing a problem with my website’s theme and I could use your help. I don’t have much programming knowledge, so I’m unable to solve it on my own.
I’ve noticed a strange change in my Scribe theme. There’s an additional tile (an image) next to my featured article, and I can’t move it to the rest of the tiles.
https://imgur.com/VZaL0OmIdeally, this large image on the left side should span the full width of the container. I hope this description is clear enough.
Could you provide your site link so we can take a closer look at the issue?
esperandzo
For now this is new website is under maitenence so there is no access. Is it possible for you to check it in other way? Or I need to remove maitenece blocade?
I have noticed that now i have problem also in diferent subwebsites… something has happend with width of conteiner? I don’t know…
We will have to see the site to diagnose. Can you provide an admin login via the private info field?
It will only be seen by the support team.
esperandzo
maitenence info has been closed so you can go to the website
the problem is in main website and in menu blog/akcje , blog/obligacje
Did you remove this CSS that comes with the template?
https://app.screencast.com/olyvYT82dpQKB -
esperandzo
Yes, I had to remove this code by mistake… I have added it and main page looks good but there is still problem in subwebsites in menu
Did you set the content container width to 800px via a layout element for the archives?
esperandzo
I think not,
Here’s screenshoot form there
https://imgur.com/a/oLEfLbK -
Can you go to appearance > elements, check if there’s a layout element which sets the content container width to 800px for the archives?
esperandzo
No, in every elements is 100% except Archive card where is 400px and featured articles where is 1200px
Can you provide an admin login so I can take a look at the elements?
esperandzo
Admin login in private information
Sorry, can you provide the password as well?
esperandzo
Link in private data
Yes, so you do have the layout element that sets the content width to 800px:
https://app.screencast.com/8h6p2RvGOEKCE
https://app.screencast.com/81MFQKpmBU7bfSimply remove this element, the issue should be fixed.
