Hello everyone,
I have a bilingual website where a logo is set up as an image in the header. A different image is required for the English version.
In WPML I have created the English alternative for the image via “Media Translation”.
Shouldn’t this be displayed automatically in the header when I switch to the English version of the website? Instead the German version is still displayed.
If I set the website language to English in the Customizer and change the image in „Website information“, I then also have the English logo on the German website.
What is my error here?
Thank you!
it should swap automatically – can you share a link to where I can see the issue on your site ?
URL is in the private section. German and english logos are there but they don’t switch.
Ok, its most likely because you’re using the navigation as header and and mobile header.
Try this PHP Snippet to swap logos:
add_filter( 'generate_logo', function( $logo ) { if ( ICL_LANGUAGE_CODE == 'en' ) { return 'URL TO ENGLISH LOGO'; } return $logo; } );For reference theres also some code for swapping mobile and sticky nav logos:
https://generatepress.com/forums/topic/elements-depending-on-language-with-wpml/page/2/#post-1842886
Tried both but nothing works …
Can you disable any image optimization on the site ? eg. caching / lazy loading, as the logos look to have been cached,
Every caching is disabled.
Just see that it works on mobile … The „Menu plus settings“-code does this. So desktop is still missing.
Is that with any of the codes applied ?
Yes, with the code on this URL: https://generatepress.com/forums/topic/elements-depending-on-language-with-wpml/page/2/#post-1842886
And if you add the code provided here:
https://generate.support/topic/change-logo-in-header-for-different-language/#post-118843
Does that apply to the desktop logo ?
No, that doesn’t work.
Can you remove the Retina Logo from the Site Identity ?
Perfect, that’s it. Will I miss the Retina Logo? It was the same size anyway.
Nope. Retina logo is from a bygone era. As most screens are now x2 or higher HD.
Fine. Thanks David!
You’re welcome
