change starter site
  • Hi! is it possible to change starter site and keep existing content. I have been having my site up for 2,5 years or so with many pages. I think now it’s to messy so I want to change but I want to keep existing pages and transfer the content to the new starter site pages. is it possible?
    By default, importing a new site library will not delete or overwrite your existing posts and pages. However as a best practice, ensure you create a full site backup before proceeding with the import or perform the import on a staging environment to mitigate potential issues.
  • Thanks! I don’t remember which start site I used. How can I see that?
  • Removing the existing site template will remove the content you imported, for example, if your current homepage is imported, it might be removed even if you’ve made changes to it.
    I would suggest making a backup of your current site then trying removing the template and importing the new template, thus even if things go wrong you can still recover the site.
