Changes not showing in mobile versions
    I am doing some changes in Customizing > Additional CSS
    And when working with media queries the code does not show.
    Here an example:
    @media (max-width: 768px) {
    #card-body {
    display:flex;
    flex-direction: column;
    I though it was due to I had activated the Cache dynamic CSS in Customizing > General but it is not that plus I do not have any other caching plugin.
    Same pattern happens when doing changes in Elements that for mobile devices it sometimes do no deploy the changes.
    The Additional CSS field is a WP core feature so this shouldn’t be a theme-related issue.
    My guess is that you have a syntax error somewhere in your CSS which stops the code below the syntax error from executing.
    You can either move the CSS above to the top of the Additional CSS to test or use a service like this to check for errors: https://jigsaw.w3.org/css-validator/#validate_by_input
