Changing default tab_is_open layout display
    Thanks for GP One,
    For the tab block, the default property for .gb-tabs__item.gb-tabs__item-open have by default the layout display: block wich prevent the display settings to take effect, when setting to flex.
    I had to change that manually with CSS.
    You can add a container as the direct child of the tab item to wrap all the content, and set display:flex to the container.
  • Thanks Ying.
  • You are welcome   🙂
