Changing Published Date Icon
  • Hello, I am trying to find where I can change the icon that is beside blog publish date after searching a blog category? I’ve tried looking under the theme template elements and that did not change the icon.
    The archive page is using a block element - content template, you should be able to find it at appearance > elements, check the elements with the location set to archives, and type set to block - content template.
    Edit the element, and locate the headline block which represents the date, you can change the icon in the icon panel in the right sidebar.
    https://docs.generateblocks.com/article/icon-overview/
