oppogenepress
Hi there
I changed the wpdm homepage template, in “cloned application” for testing, hiding download button on previous template using css “.wpdmdl btn .wpdm download link {display: none}, which is not working now on the new template, please provide the CSS related this template, further also want to change whole template of download pages as well using “CSS”, because there is no option available, the only way is to put the shortcode on every download page manually before publishing. Short codes related to templates are available,
1. try this CSS to remove the download link:
.wpdm-download-link { display: none !important; }
2. I am not sure what you require of us here. Can you explain ?
oppogenepress
Hi David, I have used the given CSS, it removes the download button from home page as well as from the download page. I just want to remove the button from the Homepage and shown in the download page through which file can be get downloaded.
Further the template used in the “download page”, of the website, can we change the whole template or make changes in the current template using custom CSS?
What is the “homepage” as i don’t see those buttons on the sites home
The Theme has no control over the WPDM plugin and its templates. If you want to customize them then you need to speak with the plugin author.
oppogenepress
Hi David
I am still unsure to what you require.
What is thehomepage
where i can see the download button that you want to remove ?
