Changing the border color of the inner container when hovering over the outer
  • Hello!
    Is there a way to change the border color of the inner container when hovering over the outer container by using effects?
    Here’s the site, so you can visualize it – https://filip.adonomy.co/ (services section just below the hero section).
    its not possible with effects.
    What you can do is NOT set a Border color on either container, by default it will inherit its parent text color. So just set the parent text and text hover colors. And both container borders should inherit it.
    IF thats no good as you may want a different text hover then let us know as it will require some CSS
  • Thanks David!
  • You’re welcome
