Changing which column shifts to top on mobile in a grid block
  • I have a grid block with two columns, by default on mobile the two columns are 100% with the lefthand column showing on top and the right column below.
    How can I change it to where to the one on the right is on top on mobile?
    link is provided in private
    select the column Container Block you want to appear first on mobile.
    Switch to mobile view.
    In the Blocks Layout -> Flex Child set the order to -1
