Anonymous
Dear support team,
I’m trying to remove unnecessary code from the header. Unfortunately, it’s not working right now. Can you help me?
I want to remove the following content from the header:
– <style>img:is([sizes=”auto” i], [sizes^=”auto,” i]) { contain-intrinsic-size: 3000px 1500px }</style>
– <style id=”classic-theme-styles-inline-css”> … </style>
– <style id=”generate-navigation-branding-inline-css”> … </style>
– <meta name=”msapplication-TileImage” content=”/wp-content/uploads/favicon-300×300.png”>In the content code I would also like to remove the Javascript.
– <script id=”generate-a11y”> … </scripts>I removed everything with the developer tool and it seems like I don’t need this information.
Kind regards
Jens -
Those style sheets come with each plugin and theme, you can NOT delete those easily.
For example, classic-theme-styles-inline-css is from WP, if you want to remove it, you need this PHP code:
add_action( 'wp_enqueue_scripts', function() { wp_dequeue_style( 'classic-theme-styles-inline-css' ); }, 20 );For the GP ones, you can disable unused premium modules at appearance > generatepress to stop them generates styles.
Others might from other plugins that I’m not aware of, so you might need to check with other plugins’s support.
Anonymous
Hi Ying,
I had already tried the code in the function.php. Unfortunately, it doesn’t work.
The code is still included.Kind regards
Jens -
In that case, you might need to check with WP’s support, as it’s from WP.
Anonymous
Hi Ying,
Can you please check if this still works for you?
Kind regards
Jens -
No, the code doesn’t work.
So please check with WP on how to disable that stylesheet 🙂
Sometimes cache plugin also has the option to disable certain stylesheets, worth a look.
