Clickable container in the loop with a scale effect on the image
  • Hello there team,
    I followed this tutorial to make the entire container clickable in my loop: https://learn.generatepress.com/blocks/block-guide/add-container-links/.
    It works great. However, in this loop, I had applied a scale effect on hover to the image, which is now not working.
    Initially, the effect was applied directly to the image on hover, but it didn’t work: https://imgur.com/KK1coYU
    I also tried adding a new selector to the created class, like img:first-of-type:hover.(https://imgur.com/undefined). In the preview editor, the scale effect works, but it doesn’t work on the front end.
    I assume the ::before pseudo-element might be covering everything? Is there a way to achieve this?
    Thankss
    You need to adjust the selector to target the image for the scale hover effect. Try this:
    1. Select the container.
    2. In the Style Selector panel, click More and add a new selector.
    3. Enter this in the Selector field: a:hover img
