Clickable container @ query loop
  • This code worked for GB v1, but it no longer works for v2. How to set up a clickable container in GB v2. Without Pro. Thank you.
    .gb-container.linked-container .gb-inside-container {
        position: relative;
    .gb-container.linked-container a:before {
        content: "";
        position: absolute;
        top: 0;
        right: 0;
        bottom: 0;
        left: 0;
        z-index: 10;
    https://prnt.sc/HjBZKjPrQwXL
    Method 1:
    You can simply set the container’s HTML tag to <a> to have a container link. But you need to make sure there is no other links inside the container, as an <a> can not be nested in another<a>.
    Method 2:
    1. Add linked-container to a container as addtional CSS class.
    2. Add this CSS:
    .linked-container {
        position: relative;
        content: "";
        position: absolute;
        top: 0;
        right: 0;
        bottom: 0;
        left: 0;
        z-index: 10;
  • I used method one. Thanks.
  • No Problem 🙂
