I created a simple dropdown menu using the amazing Accordion block. This menu will help users to navigate to different sections of the page using smooth-scroll.
I have given the single Accordion item a unique class
.vj-menu.The menu can be clicked open and closed by clicking on the Accordion Title.
Similar to the show tab contents on hover for Mega Menu built using GenerateBlocks tabs…
I would like the accordion to close as soon as anyone hovers outside the Accordion Content container?
perhaps this:
<script> document.addEventListener('DOMContentLoaded', function () { var vjMenus = document.querySelectorAll('.vj-menu'); function isMenuOpen(menu) { return menu.classList.contains('gb-accordion__item-open'); } function handleMouseOut(event) { var menu = this; var relatedTarget = event.relatedTarget; if (!menu.contains(relatedTarget)) { var toggleButton = menu.querySelector('.gb-accordion__toggle'); toggleButton.click(); menu.removeEventListener('mouseout', handleMouseOut); } } function attachMouseOutListener(menu) { menu.addEventListener('mouseout', handleMouseOut); } function handleMouseOver() { var menu = this; if (isMenuOpen(menu)) { attachMouseOutListener(menu); } } vjMenus.forEach(function (menu) { menu.addEventListener('mouseover', handleMouseOver); }); }); </script> -
Awesome thanks David. That works like a charm.
Can we also close the accordion when someone clicks on any links within the accordion?
i.e. since they have navigated to a section on the page, we no longer need to keep the menu open.
Hmmm…. try:
<script> document.addEventListener('DOMContentLoaded', function () { var vjMenus = document.querySelectorAll('.vj-menu'); function isMenuOpen(menu) { return menu.classList.contains('gb-accordion__item-open'); } function handleMouseOut(event) { var menu = this; var relatedTarget = event.relatedTarget; if (!menu.contains(relatedTarget)) { var toggleButton = menu.querySelector('.gb-accordion__toggle'); toggleButton.click(); menu.removeEventListener('mouseout', handleMouseOut); } } function attachMouseOutListener(menu) { menu.addEventListener('mouseout', handleMouseOut); } function handleMouseOver() { var menu = this; if (isMenuOpen(menu)) { attachMouseOutListener(menu); } } function handleClickInsideMenu(event) { var menu = event.currentTarget.closest('.vj-menu'); var toggleButton = menu.querySelector('.gb-accordion__toggle'); toggleButton.click(); } vjMenus.forEach(function (menu) { menu.addEventListener('mouseover', handleMouseOver); menu.querySelectorAll('.vj-menu a').forEach(function(link) { link.addEventListener('click', handleClickInsideMenu); }); }); }); </script>
