I only had problems with an update on one other website. When I change the choice for not using colors and fonts of generate press the problem was solved. 20 other website with combination elementor – generatepress without any problems.
So for http://www.wageningswijngoed.nl I cloned my website so you can look safely. The url is https://check.wageningswijngoed.nl. Same credentials.
The problems:
– What is very annoying is that the menu cannot be seen on mobile. The hamburger is white instead of black and that is not visible on a white background.
– the background of the submenu is transparent instead of color. So the text is difficult to read and it looks messy.
– if I choose distribution on messages page of 70& content and 30% right sidebar, it is displayed the other way around. the message is then 30%, very narrow.
– white text in footer is displayed in normal text color (gray)I already tried to switch of all the plugins, except Elementor. I didn’t see any improvements
Try adding this CSS:
span.mobile-menu { color: var(--global-color-8); }– the background of the submenu is transparent instead of color. So the text is difficult to read and it looks messy.
.main-navigation:not(.toggled) ul ul { background-color: var(--base-3); }– if I choose distribution on messages page of 70& content and 30% right sidebar, it is displayed the other way around. the message is then 30%, very narrow.
Try this CSS:
body.right-sidebar .site-content .content-area { width: 70%; } body.right-sidebar .site-content .is-right-sidebar { width: 30%; }– white text in footer is displayed in normal text color (gray)
This is because you’ve set the title to highlight, and chose a light color as the highlight color:
https://app.screencast.com/I7UsbStbIH8aX
https://app.screencast.com/TnQ3bRu8t1WLsYou can disable the highlight option, it should show the correct color.
lacoco
Thank you very much Ying. Your suggestions works so all fine for me. (It is time for me to learn more about css. )
Everything ok for me now.
