Hello, I’m receiving warnings in Rank Math that are the following: “Comment” object must be nested inside a “CreativeWork” object. Any suggestions on how to resolve this?
This warning can be safely ignored – as they have no effect on ranking and are a result of Google identifying any Comment schema as Discussion Forum. We will be addressing it in a future update.
Hi, I decided to go with the Info template for now. How do I add the date to the posts, and remove the template categories for example under the blog click down under blog in the menu and “select category” on the homepage?
Thanks,
Aarn -
Can you open a new topic for new questions?
which posts are you referring to? On the homepage or in each single post?
Not sure I understand what you mean by
template categories. please explain some more in your new topic. -
Sure thing, I found how to fix the issues. Thanks again!
Glad to hear that 🙂
